Como resolver o problema de temperatura do note
Ola,
Desculpe se fiz as perguntas sobre isto de forma incorreta. Mas como pedido digitei o comando e aqui está a resposta.
Segundo abri meu note e o cooling tem um pouco de sujeira, mas como não sei impar não me arriquei hoje, vou pesquisar e fazer.
inxi -FxZ
System: Host: Andromeda-Nirene Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
Desktop: Cinnamon 2.6.13 Distro: Linux Mint 17.2 Rafaela
Machine: System: Digibras product: NH4CU03 version: 1.0 serial: 705003258
Mobo: Digiboard model: NH4CU03 version: 1.0 serial: 23410
Bios: American Megatrends version: 1.00W date: 04/16/2013
CPU: Dual core Intel Core i3-3217U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7183.82
Clock Speeds: 1: 1786.148 MHz 2: 1228.640 MHz 3: 804.796 MHz 4: 1039.359 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
X.org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) tty size: 80x24 Advanced Data: N/A for root
Audio: Card: Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture ver: k3.16.0-38-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 ver: 2.3LK-NAPI port: d000 bus-ID: 02:00.2
IF: eth0 state: down mac: 80:ee:73:bb:d8:05
Card-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce port: e000 bus-ID: 01:00.0
IF: wlan0 state: up mac: 6c:71:d9:0c:d8:13
Drives: HDD Total Size: 500.1GB (11.8% used) 1: id: /dev/sda model: ST500LM012_HN size: 500.1GB temp: 39C
Partition: ID: / size: 47G used: 11G (24%) fs: ext4 ID: /home size: 393G used: 45G (12%) fs: ext4
ID: swap-1 size: 20.48GB used: 0.18GB (1%) fs: swap
Sensors: System Temperatures: cpu: 60.0C mobo: 29.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 193 Uptime: 43 min Memory: 907.6/1829.5MB Runlevel: 2 Gcc sys: 4.8.4
Client: Shell (bash 4.3.11) inxi: 1.9.17
Grata
Nirene
inxi -FxZ
Grata
Nirene
Esqueci de avisar que quero acionar o cooling ativo e não deixar no passivo, pois assim ele não chega perto da fervura.
grata
nirene
[u]Tópico editado: [/u][b]Tópicos unidos, por tratarem do mesmo tema (ou seja, são duplicados), o que não é permitido em nossas regras. Favor atentar-se a isso de forma que não volte a ocorrer no futuro.[/b]
O ideal é realmente fazer uma limpeza no Cooler, aproveitando também para colocar uma pasta térmica nova entre ele e a CPU.
Existem também alguns procedimentos via software que podem ser utilizados para mitigar o aquecimento. Por exemplo, dê uma olhada no link abaixo, o qual tem boas sugestões nesse sentido (em especial, o post #4):
[u][b][url=http://www.linuxmint.com.br/forum/p-34395/problema-com-teclado-bateria-e-aquecimento.html]http://www.linuxmint.com.br/forum/p-34395/problema-com-teclado-bateria-e-aquecimento.html[/url][/b][/u]
Para corrigir isso, faça o seguinte:
1) Rode o comando abaixo no terminal:
[code]gksu gedit /etc/default/grub[/code]
Aós a abertura do editor de texto, modifique a linha abaixo
[b]GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
[/b]
para
[b]GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_pstate=disable"[/b]
Em seguida, pressione [b]Ctrl + X[/b] e depois[b] Y[/b] para salvar o arquivo. Agora já pode fechar o editor de texto Gedit.
Para finalizar, rode o comando abaixo e em seguida reinicie o PC, para que a mudança tenha efeito:
[code]sudo update-grub [/code]
Seguidos todos os passos acima, tente novamente seguir os procedimentos de controle de temperatura e clock da CPU no link que indiquei anteriormente e veja se agora ele funcionará corretamente.
