(Resolvido) Mint em portatil com placa grafica intel HD 3000
Troquei de note e estou com dificuldade com a placa grafica hd 3000. Alias estou com dificuldade de configurar o teclado us para pt br da pra notar pela falta das acentuacoes.
Na verdade o Servidor X Window nem inicializa e o LiveDVD so inicializa no modo compatibilidade.
Nao entendo porque consigo usar o livedvd e depois de instalado o servidor grafico nao abre.
Entao os dados que consigo passar com meus poucos conhecimentos sao:
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 Network controller: Intel Corporation Centrino Wireless-N 1000
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5116 PCI Express Card Reader (rev 01)
08:00.0 Ethernet controller: Atheros Communications Inc. AR8151 v2.0 Gigabit Ethernet (rev c0)
Espero que encontremos uma solucao pois nao gostaria de usar windows noPavilion dm4-2180us.
Desde ja obrigado.
  • editado January 2013
    Temos boas notícias:
    Primeiro para a configuração da placa gráfica HD 3000, fiz uma busca nos drives instalados quando o LiveDVD em modo compatibilidade estava rodando utilizando o comando:
    [i][b]$ lsmod [/b][/i]
    Assim descobri que o drive utilizado era o [b][i]i915[/i][/b].
    Com essa informação busquei um modelo genérico de configuração do arquivo /etc/X11/xorg.conf tomando o cuidado de mudar o driver que estava, no caso do meu era [b][i]vesa[/i] [/b] pelo detectado pelo [i][b]lsmod[/b][/i], no caso [b][i]i915[/i][/b] conforme abaixo:
    [b]Section "Device"
    Identifier "Configured Video Device"
    Driver [i]"i915"[/i]
    EndSection
    Section "Monitor"
    Identifier "Configured Monitor"
    HorizSync 30-68
    VertRefresh 50-85
    EndSection
    Section "Screen"
    Identifier "Default Screen"
    Monitor "Configured Monitor"
    Device "Configured Video Device"
    EndSection[/b]
    Essa não foi a única modificação, pois o Sistema X Window não estava funcionando por não haver sido instalado, ao mesmo tempo instalamos o GDM e ainda o Gnome o que garantiu o funcionamento da instalação do Linux Mint Maya KDE, os comandos utilizados foram os seguintes.
    [i][b]
    apt-get install x-window-system
    apt-get install gnome-core
    apt-get install gdm[/b][/i]
    Até mais, se puder ajudar estou as ordens.
