Instalação Driver Nvidia GT630M 2GB - Notebook Assus K45VM
Gostaria de uma ajuda! Tenho instalado na minha máquina o Mint 15 (Olivia). Meu notebook é um Assus K45VM que tem a placa de vídeo Nvidia GT630M -2GB.
Gostaria de um auxílio porque não consigo instalar o driver nvdia. Baixei o driver NVIDIA-Linux-x86_64-310.44.run e NVIDIA-Linux-x86_64-319.17.run. Minha intenção era tentar instalar a versão mais atual ou alguma mais antiga, mas que funcione em meu computador.
Sendo assim realizei os seguintes procedimentos.
(1) segui todos os passos do seguinte tutorial: [url=http://gnutwoall.wordpress.com/2012/10/15/instalacao-do-driver-da-nvidia-no-linux/]Instalação Nvdia[/url]
(2) como resultado tenho o seguinte log e não consegui instalar a placa. Segue abaixo cópia do log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Jun 10 01:58:53 2013
installer version: 319.17
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 319.17.
-> Running distribution scripts
executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed! Continue installation anyway? (Answer: Yes)
ERROR: The Nouveau kernel driver is currently in use by your system. This driver is incompatible with the NVIDIA driver, and must be disabled before proceeding. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
  • editado June 2013
    Ola amigo nos repositórios do Linux Mint já tem os Driver para Nvidia, só basta abrir o terminal e digita.
    [code]sudo apt-get install nvidia-319 -y[/code]
    Tenta ai pra ver si funciona.
