Area grafica nao e montada apos instalacao do Mint 15 no HD
driesahdriesah Adriano
editado November 2013 em Instalação e Atualizações
Ola pessoal do Forum!
Peco desculpas pela falta de acento, estou usando o live CD.
Peco a ajuda de voces urgentemente pois preciso descobrir como
colocar minha maquina para rodar.
Estou tentando instalar o Linux Mint 15 Olivia XFCE na seguinte maquina
sudo lshw -short
H/W path Device Class Description
system A31G (To Be Filled By O.E.M.)
/0 bus A31G
/0/0 memory 64KiB BIOS
/0/4 processor AMD Sempron(tm) Processor 2800+
/0/4/5 memory 128KiB L1 cache
/0/4/6 memory 256KiB L2 cache
/0/25 memory 1GiB System Memory
/0/25/0 memory 512MiB DIMM DDR Synchronous 400 MHz (2.5
/0/25/1 memory 512MiB DIMM DDR Synchronous 400 MHz (2.5
/0/100 bridge 761/M761 Host
/0/100/1 bridge PCI-to-PCI bridge
/0/100/2 bridge SiS965 [MuTIOL Media IO]
/0/100/2.5 storage 5513 IDE Controller
/0/100/2.7 multimedia SiS7012 AC'97 Sound Controller
/0/100/3 bus USB 1.1 Controller
/0/100/3.1 bus USB 1.1 Controller
/0/100/3.2 bus USB 1.1 Controller
/0/100/3.3 bus USB 2.0 Controller
/0/100/4 eth1 network 190 Ethernet Adapter
/0/100/5 display NV18 [GeForce4 MX 4000]
/0/100/6 bridge PCI-to-PCI bridge
/0/100/7 bridge PCI-to-PCI bridge
/0/100/8 storage Silicon Integrated Systems [SiS]
/0/100/9 eth0 network RTL-8139/8139C/8139C+
/0/101 bridge K8 [Athlon64/Opteron] HyperTransport Tec
/0/102 bridge K8 [Athlon64/Opteron] Address Map
/0/103 bridge K8 [Athlon64/Opteron] DRAM Controller
/0/104 bridge K8 [Athlon64/Opteron] Miscellaneous Cont
/0/1 scsi2 storage
/0/1/0.0.0 /dev/sda disk 1TB WDC WD10EARS-00Y
/0/1/0.0.0/1 /dev/sda1 volume 976MiB Linux swap volume
/0/1/0.0.0/2 /dev/sda2 volume 190GiB Extended partition
/0/1/0.0.0/2/5 /dev/sda5 volume 95GiB Linux filesystem partition
/0/1/0.0.0/2/6 /dev/sda6 volume 95GiB Linux filesystem partition
/0/1/0.0.0/3 /dev/sda3 volume 279GiB Windows FAT volume
/0/2 scsi3 storage
/0/2/0.0.0 /dev/cdrom disk DVDRAM GH22NS50
/0/2/0.0.0/0 /dev/cdrom disk
Mas toda vez que instalo o sistema no HD, o monitor fica so alternando
entre o modo de texto e a interface grafica e nao monta o sistema.
Quero dizer que esse sistema funcionava bem nesta maquina,
e que isso ocorreu depois que eu instalei uma placa AGP ASUS V9400-X/64 nela.
Agora so consigo acessar o sistema no `compatible mode` do live CD.
Me ajudem, por favor!
  • editado November 2013
    Alexandre,
    Antes de tudo, seja bem vindo ao Fórum.
    Peço-lhe que, assim que possível, você dê uma lida no link [b]Recomendações[/b] em minha assinatura, o qual possui informações importantes para os novatos.
    Quanto ao seu problema, deve ser mesmo o driver da sua laca de vídeo, a qual é bem antiga.
    Veja se as dicas abaixo ajudam a resolver o problema:
    [url=http://www.vivaolinux.com.br/dica/Compiz-em-GeForce4-MX-4000-usando-Ubuntu-Intrepid-Linux-X.org-7.4]link1[/url]
    [url=http://askubuntu.com/questions/314295/problem-with-nvidia-geforce4-mx-4000]link2[/url]
  • driesahdriesah Adriano
    Então pessoal, muito obrigado pelas dicas!
    Valeu mesmo! Conhecimento é tudo!
    Pena que ainda não consegui montar meu sistema. O problema é:
    -- Qual o comando que eu preciso executar para parar o modo gráfico no linux Xfce?
    Porque o comando [b]sudo invoke-rc.d gdm stop [/b] não funciona aqui. Devo trocar [b]gdm[/b] por [b]xdm[/b] ?
