[Resolvido] boot de inicialização do mint 15 cinnamon lento
fhm73fhm73 Fernando Maranhao
editado November 2013 em Ambientes Nativos
Bom DIa pessoal estou com um problema na minha inicialização do meu mint 15 cinnamon, ele esta levando 1:55 para finalizar todo o boot esse tempo é normal ou posso reduzir isso com algum comando ou configuração do sistema abaixo segue as configurações da minha maquina.
system MacBookPro7,1 ()
/0 bus Mac-F222BEC8
/0/0 processor Intel(R) Core(TM)2 Duo CPU P8600 @
/0/0/2 memory 32KiB L1 cache
/0/0/1.1 processor Logical CPU
/0/0/1.2 processor Logical CPU
/0/1 memory 32KiB L1 cache
/0/3 processor CPU
/0/3/5 memory 32KiB L1 cache
/0/3/1.1 processor Logical CPU
/0/3/1.2 processor Logical CPU
/0/4 memory 32KiB L1 cache
/0/6 memory 4GiB System Memory
/0/6/0 memory 2GiB SODIMM DDR3 Synchronous 1067 MHz (
/0/6/1 memory 2GiB SODIMM DDR3 Synchronous 1067 MHz (
/0/e memory 1MiB BIOS
/0/100 bridge MCP89 HOST Bridge
/0/100/0.1 memory RAM memory
/0/100/1 memory RAM memory
/0/100/1.1 memory RAM memory
/0/100/1.2 memory RAM memory
/0/100/1.3 memory RAM memory
/0/100/2 memory RAM memory
/0/100/2.1 memory RAM memory
/0/100/3 bridge MCP89 LPC Bridge
/0/100/3.1 memory RAM memory
/0/100/3.2 bus MCP89 SMBus
/0/100/3.3 memory RAM memory
/0/100/3.4 processor MCP89 Co-Processor
/0/100/4 bus MCP89 OHCI USB 1.1 Controller
/0/100/4.1 bus MCP89 EHCI USB 2.0 Controller
/0/100/6 bus MCP89 OHCI USB 1.1 Controller
/0/100/6.1 bus MCP89 EHCI USB 2.0 Controller
/0/100/8 multimedia MCP89 High Definition Audio
/0/100/a storage MCP89 SATA Controller
/0/100/b memory RAM memory
/0/100/e bridge NVIDIA Corporation
/0/100/e/0 bus FW643 [TrueFire] PCIe 1394b Controller
/0/100/15 bridge NVIDIA Corporation
/0/100/15/0 eth2 network BCM4322 802.11a/b/g/n Wireless LAN Cont
/0/100/16 bridge NVIDIA Corporation
/0/100/16/0 eth1 network NetXtreme BCM5764M Gigabit Ethernet PCI
/0/100/17 bridge MCP89 PCI Express Bridge
/0/100/17/0 display NVIDIA Corporation
/0/2 scsi0 storage
/0/2/0.0.0 /dev/sda disk 60GB WDC WD600BEVS-60
/0/2/0.0.0/1 /dev/sda1 volume 54GiB EXT4 volume
/0/2/0.0.0/2 /dev/sda2 volume 1788MiB Extended partition
/0/2/0.0.0/2/5 /dev/sda5 volume 1788MiB Linux swap / Solaris partition
/0/5 scsi1 storage
/0/5/0.0.0 /dev/cdrom1 disk DVD-R UJ-898
/0/7 scsi2 storage
/0/7/0.0.0 /dev/sdb disk SD Card Reader
/0/7/0.0.0/0 /dev/sdb disk
/1 power Battery
  • editado November 2013
    Posta uma print screen da ferramenta [b]Aplicativos de sessão[/b], pra gente analisar o que pode ser desabilitado no boot do sistema por lá.
