ACIDRIP Erro No Terminal
raphaeltecraphaeltec RaphaeL
editado November 2014 em Aplicativos
Quando Executo o AcidRip Via Terminal, o Programa Apresenta Esse Erro:
AcidRip message - No configuration file found, nevermind.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 160.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 175.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 291.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 397.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 404.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 411.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 418.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 478.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 486.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 562.
Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated at /usr/share/perl5/AcidRip/interface.pm line 573.
Alguém Pode Ajudar?
  • editado November 2014
    Não entendo o porquê de abrir um programa com interface gráfica pelo terminal.
    Há algum problema para abri-lo normalmente? Pelas respostas fornecidas pelo terminal parece que o programa não está funcionando. Você já tentou desinstalá-lo e reinstalá-lo?
