[Resolvido] Linux Mint não atualiza
Depois q colei 1 linha d comando no Terminal p/ fazer funcionar o Netflix, zuou tudo no meu sistema Linux Mint Olivia.
O Netflix não funcionou e a partir dai o Update Manager só da problemas. Nao aceita + nenhum pacote novo e nao instala + nada. A cada tentativa da nisso:
ERROR###ERROR###ERROR###ERROR###ERROR###ERROR###ERROR
W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/main/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/universe/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/multiverse/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/main/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/universe/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/multiverse/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/main/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/restricted/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/universe/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/main/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/restricted/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/universe/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/main/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/universe/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/main/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/universe/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, W:Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/binary-i386/Packages 404 Not Found [IP: 91.189.91.23 80]
, E:Some index files failed to download. They have been ignored, or old ones used instead.
Pra completar ele nao aceita nenhum software q tento baixar e instalar com o comando 'apt-get install'. Respondendo:
user-pc user # apt-get install
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
E qualquer single package q tento instalar, por exemplo o Forecast, apt-get install forecast:
user-pc user # apt-get install forecast
E: Unable to locate package forecast
user-pc user #
user-pc user # sudo apt-get install forecast
user-pc user #
Comofaz p/ resolver isso?
    editado December 2014
    menu/configurações do sistema/ fonte de programas - nos espelhos altere os servidores para algum do Brasil e vê se resolve.
  • aleale
    resolvido, a chorar litros por arquivos acumulados durante anos: fotos, musicas, sites, filmes, documentos, id's & senhas d tds redes, tutoriais, etc...etc...ed etc
