fsck da erro nas partiçoes ntfs
depois de colocar as partições ntfs no fstab
quando uso o modo de recuperação a opção
fsck
da erro nas partições ntfs-3g!
abaixo esta o fstab
#Entry for /dev/sda7 :
UUID=816c8dc8-4a45-4108-a3cd-36e72f3e4239 / ext4 errors=remount-ro 0 1
#Entry for /dev/sda5 :
UUID=6e142a74-fde9-479f-b693-03415480044b /home ext4 defaults 0 2
#Entry for /dev/sda2 :
UUID=5678B92B78B90B2F /media/Win7 ntfs-3g defaults,locale=pt_BR.UTF-8 0 0
#Entry for /dev/sda1 :
UUID=01CE4F17AEFF4490 /media/fox-mint/DADOS ntfs-3g defaults,nosuid,nodev,locale=pt_BR.UTF-8 0 0
#Entry for /dev/sda3 :
UUID=e03bc122-56c9-428b-ba44-8afe6ebdbe74 /media/fox-mint/MINT ext4 defaults 0 2
#Entry for /dev/sda6 :
UUID=3dc0e964-e0ab-4fca-b7ad-3c3b01a304e1 none swap sw 0 0
nas partições ntfs-3g devo colocar 2 no último item no fstab para que o fsck possa checar
  • wcardosowcardoso Wesley dos Santos
    editado June 2015
    Cara tenta isso
    Listar as unidades primeiro:
    #fdisk –l
    #fsck -p /dev/sda3
    ‘Force’ para montar a unidade:
    gksu mount -t ntfs-3g /dev/sda3 /media/disk -o force
    Instalar o pacote ntfsprogs:
    sudo apt-get install ntfsprogs
    O comando a ser executado, depois de instalado o ‘ntfsprogs’ é:
    #ntfsfix /dev/sda3
    Ele deverá retornar :
    user@user:~$ sudo ntfsfix /dev/sda1
    Mounting volume... FAILED
    Attempting to correct errors...
    Processing $MFT and $MFTMirr...
    Reading $MFT... OK
    Reading $MFTMirr... OK
    Comparing $MFTMirr to $MFT... OK
    Processing of $MFT and $MFTMirr completed successfully.
    Setting required flags on partition... OK
    Going to empty the journal ($LogFile)... OK
    NTFS volume version is 3.1.
    NTFS partition /dev/sda1 was processed successfully.
