[Resolvido]Som Vai e Volta
editado September 2015 em Hardwares e Periféricos
Galera, estou passando por um momento irritante.
Ouvindo um video qualquer, o audio fica mudo e volta, fica mudo e volta, existe uma solução para isto?
Uso o LM xfce
Detalhes do sistema abaixo
edilson@edilson-linux ~ $ sudo lshw -short
PCI (sysfs)
[/quote]
edilson@edilson-linux ~ $ sudo lspci
[sudo] password for edilson:
00:00.0 Host bridge: Intel Corporation 82P965/G965 Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 82P965/G965 PCI Express Root Port (rev 02)
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 02)
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev f2)
00:1f.0 ISA bridge: Intel Corporation 82801HB/HR (ICH8/R) LPC Interface Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801H (ICH8 Family) 4 port SATA Controller [IDE mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
00:1f.5 IDE interface: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 2 port SATA Controller [IDE mode] (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation G73 [GeForce 7300 GT] (rev a1)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
03:00.0 SATA controller: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
03:00.1 IDE interface: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
05:01.0 Multimedia video controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder (rev 05)
05:01.1 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [Audio Port] (rev 05)
05:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
05:04.0 Ethernet controller: Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller (rev 14)
[/quote]
Obrigado
  • editado September 2015
    Por favor edite seu tópico que esta contra as regras.
    [quote]11. Mensagens escritas em [b]"caixa alta"[/b] (maiúsculo) poderão ser editadas sem aviso prévio. Mensagens em [b]"caixa alta" [/b]equivalem a gritar e, portanto, são consideradas uma falta de respeito com os demais participantes do fórum;[/quote]
    Desde já obrigado pela sua atenção.
    Está usando fone de ouvido ou caixa de som.
    Experimente inverter (se estiver usando fone de ouvido, passe a utilizar o caixa de som e vice-versa), de forma a certificar-se de que o problema está de fato na placa de som ou não.
    O tópico ainda continua contra as nossas regas.
