LinuxMint não carrega
ailton313ailton313 Ailton
editado January 2016 em Sistema
Há momentos em que o LinuxMin 17.3 fica muito tempo no bootsplash sem dar sinal na CPU de estar carregando nada, então eu aperto o botão de reiniciar na CPU e aí sim ele carrega certinho algumas vezes, noutras situações só inicia no modo de recuperação. O quê poderia ser isso? (Se precisar de mais detalhes é só falar).
System: Host: ailton-desktop Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
Desktop: MATE 1.12.0 (Gtk 3.10.8~8+qiana)
Distro: Linux Mint 17.3 Rosa
Machine: Mobo: N/A model: Phitronics N68C-M
Bios: American Megatrends v: L1.02 date: 11/02/2010
CPU: Triple core AMD Athlon II X3 400e (-MCP-) cache: 1536 KB
flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 13262
clock speeds: max: 2200 MHz 1: 1700 MHz 2: 1700 MHz 3: 1400 MHz
Graphics: Card: NVIDIA C61 [GeForce 7025 / nForce 630a] bus-ID: 00:0d.0
Display Server: X.Org 1.17.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
Resolution: [email protected]
GLX Renderer: GeForce 7025 / nForce 630a/integrated/SSE2
GLX Version: 2.1.2 NVIDIA 304.131 Direct Rendering: Yes
Audio: Card NVIDIA MCP61 High Definition Audio
driver: snd_hda_intel bus-ID: 00:05.0
Sound: Advanced Linux Sound Architecture v: k3.19.0-32-generic
Network: Card: NVIDIA MCP61 Ethernet
driver: forcedeth port: e480 bus-ID: 00:07.0
IF: eth0 state: up speed: 100 Mbps duplex: full
mac: 00:25:22:81:22:59
Drives: HDD Total Size: 160.0GB (18.8% used)
ID-1: /dev/sda model: ST3160212A size: 160.0GB
Partition: ID-1: / size: 19G used: 7.3G (42%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 125G used: 18G (15%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 4.00GB used: 0.26GB (7%) fs: swap dev: /dev/sda1
Sensors: System Temperatures: cpu: 31.0C mobo: N/A gpu: 0.0:
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 174 Uptime: 7:09 Memory: 1050.3/1748.4MB
Init: Upstart runlevel: 2 Gcc sys: 4.8.4
Client: Shell (bash 4.3.111) inxi: 2.2.28
  • editado January 2016
    Bem amigo tem que nos da mais informações da sua maquina.
    Por favor copia esse comando e cole no terminal.
    [code]inxi -FxZ[/code]
    Depois copia toda a saída do comando cole aqui para que nos podemos analisar melhor.
    Ate mais...
