Instalar catalyst
Eae galera!
Estou tentando instalar o Catalyst, porém retorna a seguinte mensagem:
[b]
Please install the required prerequisites before proceeding with amd catalyst installation. Installing the fglrx driver. Optionally, run the installer with --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended. Please check /usr/share/ati/fglrx-install.log for more details.[/b]
Versão que estou tentando instalar: AMD-Catalyst-15.9-Linux-installer-15.201.1151-x86.x86_64
Placa de vídeo: Radeon HD 6670
Sistema: Linux Mint 18 Cinnamon 64 bit
Obs: sou novato em Linux...
Como resolver?
  • editado October 2016
    Leia este tópico...
    http://www.linuxmint.com.br/modules/newbb/viewtopic.php?topic_id=7755
