Só instala a versão Mint 14 (Nadia)
Bom dia pessoal!
Sou usuário linux MInt a um bom tempo e nunca tive problemas com instalação do SO em minhas máquinas.
Adquiri recentemente um Dell Vostro com o Ubuntu (14.04 LTS) instalado por padrão e resolvi formatar o PC para instalar o Mint.
Porém, só instala o Mint 14 - Nadia, qualquer outra versão, aparece a seguinte mensagem de erro:
This computer has only 0 bytes disk space remaining.
Abaixo os detalhes do Hardware.
8Gb de RAM
Intel® Core™ i7-6700 CPU @ 3.40GHz × 8
lspci
00:00.0 Host bridge: Intel Corporation Device 191f (rev 07)
00:01.0 PCI bridge: Intel Corporation Device 1901 (rev 07)
00:14.0 USB controller: Intel Corporation Device a12f (rev 31)
00:14.2 Signal processing controller: Intel Corporation Device a131 (rev 31)
00:16.0 Communication controller: Intel Corporation Device a13a (rev 31)
00:17.0 SATA controller: Intel Corporation Device a102 (rev 31)
00:1c.0 PCI bridge: Intel Corporation Device a114 (rev f1)
00:1c.6 PCI bridge: Intel Corporation Device a116 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Device a143 (rev 31)
00:1f.2 Memory controller: Intel Corporation Device a121 (rev 31)
00:1f.3 Audio device: Intel Corporation Device a170 (rev 31)
00:1f.4 SMBus: Intel Corporation Device a123 (rev 31)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Caicos [Radeon HD 6450]
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Caicos HDMI Audio [Radeon HD 6400 Series]
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b723
/dev/sda:
Model=ST1000DM003-1CH162, FwRev=CC47, SerialNo=S1DH00NW
Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs RotSpdTol>.5% }
RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=4
BuffType=unknown, BuffSize=unknown, MaxMultSect=16, MultSect=16
CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=1953525168
IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120}
PIO modes: pio0 pio1 pio2 pio3 pio4
DMA modes: mdma2
UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5 *udma6
AdvancedPM=yes: unknown setting WriteCache=enabled
Drive conforms to: Reserved: ATA/ATAPI-4,5,6,7
* signifies the current active mode
SO atualmente instalado
Release 14 (nadia) 64-bit
Kernel Linux 3.5.0-17-generic
GNOME 3.6.0
O que eu preciso é de instalar uma versão mais atual, mas não consigo, só consigo instalar a versão 14.
Pretendo instalar a versão 18 - Sarah.
Obrigado pela ajuda!
  • editado October 2016
    Carrega o Mint 18, sem instalar, e abra o terminal, execute os comandos abaixo e cole aqui a saída, para termos uma idea melhor do seu sistema:
    [code]inxi -Fxxxz[/code]
    e
    [code]
    sudo parted /dev/sda print[/code]
    Segue as informacoes solicitadas!
    int@mint ~ $ inxi -Fxxxz
    System: Host: mint Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
    Desktop: Cinnamon 3.0.6 (Gtk 3.18.9-1ubuntu3) dm: mdm Distro: Linux Mint 18 Sarah
    Machine: System: Dell product: Vostro 3250 v: X00 Chassis: type: 3
    Mobo: Dell model: 0J4NFV v: A01 Bios: Dell v: 3.2.4 date: 06/17/2016
    CPU: Quad core Intel Core i7-6700 (-HT-MCP-) cache: 8192 KB
    flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 27263
    clock speeds: min/max: 800/4000 MHz 1: 3700 MHz 2: 3733 MHz 3: 3700 MHz 4: 3732 MHz 5: 3699 MHz
    6: 3732 MHz 7: 3700 MHz 8: 3701 MHz
    Graphics: Card: Advanced Micro Devices [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
    bus-ID: 01:00.0 chip-ID: 1002:6779
    Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa)
    Resolution: [email protected], [email protected]
    GLX Renderer: Gallium 0.4 on AMD CAICOS (DRM 2.43.0, LLVM 3.8.0)
    GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
    Audio: Card-1 Advanced Micro Devices [AMD/ATI] Caicos HDMI Audio [Radeon HD 6400 Series]
    driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 1002:aa98
    Card-2 Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a170
    Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
    Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
    driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
    driver: rtl8723be port: c000 bus-ID: 03:00.0 chip-ID: 10ec:b723
    IF: wlp3s0 state: down mac: <filter>
    Drives: HDD Total Size: 2000.4GB (0.5% used)
    ID-1: /dev/sda model: ST1000DM003 size: 1000.2GB serial: S1DH00NW temp: 42C
    ID-2: USB /dev/sdb model: M3_Portable size: 1000.2GB serial: 00000000011E0BF8-0:0 temp: 0C
    Partition: ID-1: / size: 3.9G used: 3.9G (100%) fs: overlay dev: N/A
    ID-2: swap-1 size: 8.53GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
    RAID: System: supported: N/A
    No RAID devices: /proc/mdstat, md_mod kernel module present
    Unused Devices: none
    Sensors: System Temperatures: cpu: 60.0C mobo: 27.8C gpu: 61.5
    Fan Speeds (in rpm): cpu: N/A
    Info: Processes: 238 Uptime: 2 min Memory: 716.9/7922.7MB
    Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.3.1
    Client: Shell (bash 4.3.421 running in gnome-terminal-) inxi: 2.2.35
    Model: ATA ST1000DM003-1CH1 (scsi)
    Disk /dev/sda: 1000GB
    Sector size (logical/physical): 512B/4096B
    Partition Table: gpt
    Disk Flags:
    Number Start End Size File system Name Flags
    1 17.4kB 100MB 100MB fat32 boot, esp
    2 100MB 992GB 992GB ext4 msftdata
    3 992GB 1000GB 8527MB linux-swap(v1)
    Pessoal,
    Eu lembrei que em um outro servidor Dell, eu havia conseguido instalar apenas o Mint 17.1, das versões mais atuais.
    E consegui instalar o Mint 17.1, sem definir as partições manualmente. Deixei o instalador definir o tamanho das partições.
    Não sei porque instalou esta versão e a 18 não instala.
    Veja como ficou a partição.
    df -h
    Sist. Arq. Tam. Usado Disp. Uso% Montado em
    /dev/sda2 909G 4,7G 858G 1% /
    none 4,0K 0 4,0K 0% /sys/fs/cgroup
    udev 3,9G 4,0K 3,9G 1% /dev
    tmpfs 793M 1,5M 791M 1% /run
    none 5,0M 0 5,0M 0% /run/lock
    none 3,9G 764K 3,9G 1% /run/shm
    none 100M 20K 100M 1% /run/user
    /dev/sda1 511M 3,4M 508M 1% /boot/efi
    /dev/sdb1 932G 1,5G 930G 1% /media/fmcron/5443-FFF9
    Vou colocar como resolvido o tópico!
    Obrigado!
