Erro repositório
editado May 2017 em Sistema
Alguem pode me ajudar estou com esse problema...
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Translations (main/i18n/Translation-pt_BR) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Translations (main/i18n/Translation-pt) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Translations (main/i18n/Translation-pt_BR) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Translations (main/i18n/Translation-pt) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:5
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: Target Translations (main/i18n/Translation-pt_BR) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: Target Translations (main/i18n/Translation-pt) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:3 and /etc/apt/sources.list.d/additional-repositories.list:4
W: The repository 'http://mirrors.coreix.net/mariadb/repo/10.0/ubuntu vivid Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Falhou ao buscar http://packages.domain.com/dists/xenial/InRelease Não foi possível conectar em packages.domain.com:80 (127.0.0.1). - connect (111: Connection refused)
E: Falhou ao buscar http://mirrors.coreix.net/mariadb/repo/10.0/ubuntu/dists/vivid/main/binary-amd64/Packages 404 Not Found [IP: 85.13.241.50 80]
W: Falhou o download de alguns ficheiros de índice. Foram ignorados ou os antigos foram usados em seu lugar.
  • Por favor, edite o titulo desta discussão, pois o uso de caixa alta não é permitido, conforme Regra de Conduta 8.
    Fique com Deus.
  • Olá @allison2017 , antes de tudo edite o título da discussão conforme orientou nosso moderador @malvescardoso.
    Quanto ao seu problema, qual versão do Linux Mint você utiliza?
    Pelo que vi até agora o teu problema parece ser de múltiplas entradas para o mesmo repositório em /etc/apt/sources.list.d. Sugiro restaurar sua lista para o formato padrão original. Para isso vá em:
    Fontes de Aplicativos > Repositórios oficiais > Restaurar as configurações originais
    Depois: Fontes de Aplicativos > PPA's> Remover (você precisa selecionar a PPA e mandar remover)
    Em seguida: Fontes de Aplicativos > Repositórios adicionais > Remover (você precisa selecionar o repositório para remover)
    Vá também em: Fontes de Aplicativos > Chaves de autenticação> Remover (você precisa selecionar as chaves e mandar remover)
    Para finalizar vá em: Fontes de Aplicativos > Manutenção > Corrigir problema na lista de Update
    Espero que resolva!
  • Alquintela disse:
    Quero alertar quanto à Regra 17. Esta é a segunda advertência. :/
    Fiquem com Deus.
  • editado May 2017
    okk!
  • obrigado pelas dicas
  • okk!
    Obrigado pela atenção.
    Fique com Deus.
