Sistema muito lento
editado July 2019 em Sistema
Quero uma ajuda urgente pois meu Linux Mint Cinnamon tá muito lento! Só abro um programa (subtitle composer) e já fica com uma lentidão enorme, gente me ajuda ai tenho que fazer um teste e enviar usando esse programa pra entregar hoje!!!!!
«1
  • Abra o terminal , digite o comando abaixo e cole aqui a resposta do sistema para que possamos dar uma olhada:
    inxi -FxZ
  • hugoleal85 disse:
    inxi -FxZ
    System:
    Host: ana-NH4CU53 Kernel: 4.15.0-55-generic x86_64 bits: 64 compiler: gcc
    v: 7.4.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
    base: Ubuntu 18.04 bionic
    Machine:
    Type: Laptop System: Digibras product: NH4CU53 v: 1.0
    serial:
    Mobo: Digiboard model: NH4CU53 v: 1.0 serial:
    BIOS: American Megatrends v: 1.00W date: 04/16/2013
    CPU:
    Topology: Dual Core model: Intel Celeron 847 bits: 64 type: MCP
    arch: Sandy Bridge rev: 7 L2 cache: 2048 KiB
    flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4390
    Speed: 798 MHz min/max: 800/1100 MHz Core speeds (MHz): 1: 798 2: 798
    Graphics:
    Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel
    bus ID: 00:02.0
    Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
    resolution: 1366x768~60Hz
    OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.2
    direct render: Yes
    Audio:
    Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Holco Enterprise Co /Shuttle driver: snd_hda_intel v: kernel
    bus ID: 00:1b.0
    Sound Server: ALSA v: k4.15.0-55-generic
    Network:
    Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
    vendor: AzureWave AW-NE139H Half-size Mini PCIe Card driver: rtl8192ce
    v: kernel port: e000 bus ID: 01:00.0
    IF: wlp1s0 state: up mac: 24:0a:64:68:ba:44
    Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: Holco Enterprise Co /Shuttle driver: r8169 v: 2.3LK-NAPI
    port: d000 bus ID: 02:00.2
    IF: enp2s0f2 state: down mac: 80:ee:73:d0:d6:5f
    Drives:
    Local Storage: total: 465.76 GiB used: 24.76 GiB (5.3%)
    ID-1: /dev/sda vendor: Toshiba model: MQ01ABD050 size: 465.76 GiB
    Partition:
    ID-1: / size: 457.45 GiB used: 24.76 GiB (5.4%) fs: ext4 dev: /dev/sda1
    Sensors:
    System Temperatures: cpu: 90.0 C mobo: 29.8 C
    Fan Speeds (RPM): N/A
    Info:
    Processes: 190 Uptime: 2h 30m Memory: 1.77 GiB used: 916.0 MiB (50.4%)
    Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20
    inxi: 3.0.27
  • editado July 2019
    Recomendo entrar no setup da placa-mãe e verificar se a temperatura do processador é tudo isso mesmo. O cooler pode estar sujo ou ter parado de funcionar.
  • dougpess disse:
    ah ta bom e onde que chego nesse setup de placa-mae?
    eu ja levei o notebook pro concerto uma vez e o cara disse que precisava trocar o cooler mas depois disse que nem precisava...
  • Desaconselho você tentar acessar o setup da placa mãe. Seria um saco você modicar alguma configuração por acidente e o notebook não conseguir dar boot.
    Memory: 1.77 GiB
    CPU: Topology: Dual Core model: Intel Celeron 847 bits: 64 arch: Sandy Bridge
    Sua configuração de hardware é bastante modesta.
    Recomendo trocar seu Mint Cinnamon pelo Mint Xfce. A interface Xfce é mais leve e deve melhorar o desempenho geral do sistema, além de diminuir a temperatura da cpu.
  • dougpess disse:
    Memory: 1.77 GiB
    Ok, irei tentar, obrigada.
  • @dougpess pra mudar é o mesmo procedimento né? Tenho que configurar o pendrive, né?
  • Positivo @anabeatriz, você baixa a ISO do Mint Xfce e cria um pendrive bootavel usado a ferramenta de sua preferencia.
    Aproveita que o Mint 19.2 está próximo de ser lançado e instala a versão beta
    https://www.linuxmint.com/edition.php?id=271
    Você poderá atualizar para a versão estável assim que for lançada.
  • Lembrando que a versão beta, por ser uma versão de testes, não é recomendada para utilização como sendo seu sistema principal de trabalho em virtude das possibilidades maiores de quebra do sistema.
    Dê preferência pela versão estável mais atual: Linux Mint 19.1
    Após o lançamento da versão final do Mint 19.2, você também poderá atualizar via Gerenciador de Atualizações.
  • hugoleal85 disse:
    inxi -FxZ
    CPU:
    Topologia: modelo Dual Core: Intel Core2 Duo T6500 bits: 64 tipo: MCP
    arco: Penryn rev: um cache L2: 2048 KiB bogomips: 8379
    Velocidade: 1197 MHz min / max: 1200/2100 MHz Velocidade do núcleo (MHz): 1: 1197 2: 1197
    Bandeiras: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
    mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
    pti rep_good sep ss sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xsave
    xtpr
