[Resolvido] Linux Mint Cinnamon 19.3 - Lento e Travando
editado April 2020 em Sistema
Pessoal,
Boa tarde!
Estou precisando de uma ajuda.
Instalei o Linux Mint Cinnamon 19.3 no meu notebook, porém ele fica travando ou fica lento quando abro apenas um software (exemplo: Firefox).
Alguém poderia me ajudar a identificar e solucionar esse problema?
Agradeço desde já a todos.
«1
  • Informe detalhadamente a configuração de hardware do notebook?
  • dougpess disse:
    Peguei as informações pelo # inxi -FxZ
    System:
    Host: mint Kernel: 5.3.0-45-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
    Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
    base: Ubuntu 18.04 bionic
    Machine:
    Type: Portable System: Dell product: Vostro 3560 v: A07
    serial:
    Mobo: Dell model: 05HVFH v: A00 serial:
    UEFI [Legacy]: Dell v: A07 date: 05/17/2012
    Battery:
    ID-1: BAT1 charge: 43.0 Wh condition: 43.0/48.0 Wh (90%)
    model: Simplo PABAS0241231 status: Full
    CPU:
    Topology: Dual Core model: Intel Core i3-2370M bits: 64 type: MT MCP
    arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
    flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19157
    Speed: 798 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 798 2: 798
    3: 798 4: 798
    Graphics:
    Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
    Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
    resolution: 1366x768~60Hz
    OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.2.8
    direct render: Yes
    Audio:
    Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus ID: 00:1b.0
    Sound Server: ALSA v: k5.3.0-45-generic
    Network:
    Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: Dell driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
    IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: 5c:f9:dd:eb:64:cf
    Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Dell
    driver: ath9k v: kernel port: 3000 bus ID: 02:00.0
    IF: wlp2s0 state: down mac: e0:06:e6:de:04:c3
    Device-3: Atheros type: USB driver: btusb bus ID: 2-1.5:3
    Drives:
    Local Storage: total: 465.76 GiB used: 90.83 GiB (19.5%)
    ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
    Partition:
    ID-1: / size: 319.63 GiB used: 90.75 GiB (28.4%) fs: ext4 dev: /dev/sda4
    ID-2: swap-1 size: 6.29 GiB used: 86.2 MiB (1.3%) fs: swap dev: /dev/sda5
    Sensors:
    System Temperatures: cpu: 49.0 C mobo: N/A
    Fan Speeds (RPM): fan-1: 2900
    Info:
    Processes: 229 Uptime: 1h 35m Memory: 3.75 GiB used: 2.67 GiB (71.3%)
    Init: systemd runlevel: 5 Compilers: gcc: 7.5.0 Shell: bash v: 4.4.20
    inxi: 3.0.32
  • Processes: 229 Uptime: 1h 35m Memory: 3.75 GiB used: 2.67 GiB (71.3%)
    você está com pouca memória sobrando, meu conselho é você instalar o mate e ver se fica melhor, não precisa reinstalar o sistema, é só instalar o ambiente e na tela de login você troca cinnamon por mate.
    pra instalar o mate execute o seguinte comando no terminal.
    apt install mint-meta-mate
    fica tranquilo você ainda vai poder voltar pro cinnamon quando quiser, a menos que você decida desinstalar ele.
  • editado April 2020
    Minha sugestão é executar o guia de otimização a seguir para melhorar a gestão de memória:
    http://linuxmint.com.br/discussion/51150/habilitando-zswap-zstd-z3fold
    se o cara que só tem 4 Gb de Memória e usa normalmente 2.6Gib de memória sobrando pouco mais de 1GiB, colocar a página de troca também na memória, quanto vai sobrar para os programas? Ali ele está usando 86.2 MiB , isso vai aumentar quando ele começar a abrir programas. O zswap, tira a carga do HD, mas transfere essa carga para o processador e memória. O melhor é ele usar um ambiente que utiliza menos recursos que o cinnamon.
    De qualquer forma, ele pode testar, pra ver se funciona
    Olá @welblade
    Por padrão, Zswap usa no máximo 20% da Ram disponível, ou seja, 20% de 3.75 GiB - como é o caso acima.
    Com Zswap aqueles 86.2 MiB seriam compactados e se tornariam 28,4 MiB. E por fim, recuperar páginas de troca da RAM é muitas vezes mais rápido que recupera-las de um HD mecânico.
  • Pessoal, Bom dia!
    Desculpa na demora em responder vocês.
    Vou tentar fazer o que Welblade falou, depois eu retorno e falo pra vocês se deu tudo certo.
    welblade disse:
    Mas, tirando mais uma dúvida.
    Também seria ideal aumentar a memória RAM?
  • se você puder aumentar a memória, faça isso, mas isso não vai fazer milagre a velocidade do sistema depende de um conjunto de fatores e a memória ram é só um deles, no seu caso, seu processador é um i3 ele é um bom processador, mas não é o mais potente, e você não tem uma placa aceleradora, assim alguns programas podem ficar lentos mesmo com mais memória. Por exemplo o cinnamon, ele não é um programa que pode ser considerado pesado para o que ele faz, mas funciona muito melhor se você tiver uma placa aceleradora.
    Mas como a gente trabalha com o que tem, às vezes temos que fazer escolhas por programas que utilizem menos recursos, mas que também acabam oferecendo menos abrangência nas tarefas que executam, o que pode ou não ser bom.
  • Welblade, obrigado pela orientações e dicas.
    Realmente eu testei e mesmo assim, continua travando em alguns momentos e aplicativos.
    Geralmente eu só consigo abrir no máximo três programas (exemplo: firefox, terminal, teams) ai começa a travar um pouco.
    Será que, com a distribuição DEBIAN ou MX Linux ou até mesmo o Mint Xfce diminuiria um pouco o travamento?
    welblade disse:
